Baler Twine
Bgee
04-07-2001 08:11:32
I Bought a J.D. 24t last spring. It's baling fine with the twine I'm using, but the twine looks bad to me, all twisted up and wrinkly and frayed. Where and what brand of hemp twine is best? Thanks
B..C.
04-10-2001 14:17:13
 Re: Baler Twine in reply to Bgee, 04-07-2001 08:11:32
I think it's more how fresh the twine is than the brand name. Along with that, try to find out if what you're buying was "stashed" (to coin a phrase) down in the cellar over the winter or is just in from Brazil.
Go for the fresh stuff, dude.
Charlie
04-10-2001 18:26:14
 Re: Re: Baler Twine in reply to B..C., 04-10-2001 14:17:13
You make a good point - damp twine doesn't work in any baler. Also, watch twine that has set over the winter in your baler - mice love to over winter in it and they can mess up a whole ball making it useless.
paul
04-08-2001 20:27:05
I've had pretty good luck with most brands, I think it depends on your knotters - if they are working good, it should work out.
I think you want sisal twine, haven't seen hemp? Would make burning the twine a whole new experience....
--->Paul
rhudson
04-08-2001 16:07:10
Bgee, i've seen New Holland twine that had very little twist and looked ragged, but was as strong or stronger as other brands that had lots of twist. i think its a function of how long the fiber is. short fibers need more twist to be as strong as long fibered twine. long fiber cost the producer more. i round bale so i purchase the cheapest sisal. to me plastic is a pollutant, i will not allow it on the farm again. anyway i try to alternate different colored twine, that gives me an idea how many balls i've been through.
Tim(nj)
04-07-2001 12:05:54
Where DO you get hemp twine? Around here it's either plastic or sisal. Nothing else. I use plastic myself, as my customers prefer it (go figure?)
Bgee
04-10-2001 07:15:53
 Re: Re: Baler Twine in reply to Tim(nj), 04-07-2001 12:05:54
Sorry, sisal is what I meant. Thanks for info.
