3 bottom plow
Frank Hutson
04-11-2001 19:09:23
I am trying to identify the manufacturer of a three bottom 16" plow. It is painted all yellow and the part nos. are (ie EP862) all nos. begin with EP some have an X following the number. It is built "Strong". The tongue is adjustable on an arc for proper draft. A lever adjusts the furrow wheel, a trip lever activates the land wheel which has a rubber tire on cut off wheel.
Any clue as to what it is would be much appreciated. Thanks
Bob Collins
04-12-2001 07:25:17
 Re: 3 bottom plow in reply to Frank Hutson, 04-11-2001 19:09:23
Frank, I can tell you that because the casting numbers start with EP it is an Oliver plow, if you go to the Oliver discussion board and give a more complete description I'm sure some one will know more. Bob
