Dearborn rear mower
Tim
04-18-2001 12:27:00
Does anyone know how to properly hook up to a 14-73 Dearborn mower. I hooked up to it the way I thought was right but I can't raise the lift up hardly at all without the bar running under the axle twisting and rubbing against the bolt that holds the lift arm in place. Could it be a problem tith the spring or cable being to long. Any help is greatly appreciated
Jerry D in NC
04-19-2001 12:56:55
 Re: Dearborn rear mower in reply to Tim, 04-18-2001 12:27:00
What are you mounting this mower to. Do you have the bracket that the pin on that rod goes into where the stabilizer bar connects under the fender?
Tim
04-23-2001 06:30:56
 Re: Re: Dearborn rear mower in reply to Jerry D in NC, 04-19-2001 12:56:55
I'm mounting this to a Ford 860 and yes I have the bracket that it fastens to. The problem I'm having is that I can't raise the lift without it binding under the axle and pushing against my toolbox. I guess I'm really most curious why I can't raise the implement hardly at all.
Jerry D in NC
04-25-2001 04:24:01
 Re: Re: Re: Dearborn rear mower in reply to Tim, 04-23-2001 06:30:56
Tim If it is the mower I am thinking of, it was made to fit a 9/2/8N which had I think lift arms that were about 2" shorter than what is on your 860. Thus making that rod no longer proportioned properly. I am talking from 20 year old memories here because we tried to make one work on a 2000 and it would not. Those mowers on a 8N makes a heck of a hay cutting machine but I am not sure that you can get it to work on the 860. Do not take me for a final authority but maybe a direction to look.
