2-bottom disc plow-Help
Tom
04-22-2001 08:46:33
I have a 2 disc breaking plow Dearborn, We have tried it on a 2640 JD,3910 Ford,3930 Ford plenty of Hp all it does is pull the tractor sideways if you run the right wheel in the furrow it will pull you side ways we have adjusted it everyway we can and no luck The tires on the tractos are in all the way and the plow does have the furrow wheel in the back Trying to plow 6-8 inches deep and can,t keep it in the ground level either too deep or too shallow JUST HAVING BAD LUCK Any help would be greatly appreciated Thanks
Tom-Pa trying to get link
04-22-2001 10:42:06
 Re: 2-bottom disc plow-Help in reply to Tom, 04-22-2001 08:46:33
trying to get link to post..
Good luck
Tom-Pa
Tom-Pa
04-22-2001 10:38:43
depending on which model plow you have there are several ways of adjusting them..if with the ferguson stlye lift arm attch points, get the ferguson plow manual..shows measurements and how to adjust for plowing.. lots of good info in there..check with n-newsletter and check the archives for the model plow you have...you may be able to come up with a xeroxed copies of a manual..they list both ferguson and dearborn equipment that they have copies of ..
Good luck
Tom-Pa
