#55 New Holland Hay Rake
Jerry D in NC
04-23-2001 18:25:59
I just obtained a 55 for free but needs some TLC. Needs a male PTO drive from the wheel to the gearbox. Doesn't have any paint but everything seems to be free and ready to run. Just ordered the manuals from FNH but does anyone have any sage advice about these rakes?????
Debbie B
06-24-2003 05:04:16
 Re: #55 New Holland Hay Rake in reply to Jerry D in NC, 04-23-2001 18:25:59
What lubrication goes into the gear box? I assumed 90wt gear oil, but a JD serviceman recommended grease because it wouldn't run out around the seal, but would liquify enough to work. Any ideas?
lanny cothern
12-17-2004 09:14:54
 Re: Re: #55 New Holland Hay Rake in reply to Debbie B, 06-24-2003 05:04:16
I have this same rake i use grease in mine for the last 5 years and it works
Dick Leslie
06-12-2003 09:33:24
A Friend Of Mine Is Looking For A Gear Box For A New Holland Mod.56 Hay Rake,Any Help Would Be Welcome We Live In A Little Town In South Central Pa. Thank You Dick.
paul
04-24-2001 23:15:57
If the NH parts gives you sticker shock, I'd look through the farm supply stores, they carry a pretty good selection of pto shaft parts.
--->Paul
Phil
04-24-2001 11:24:19
I have a super 55 rake which I assume is similar to yours. The main difference between it and the later ones is on the later ones there is a univeral joint on the left rear axle to bring the right rear wheel in close to the rake. This makes the rake follow the contours of the ground better. On the 55 if you go up a hill or have any bumps in your field the teeth will scrape the ground before the wheel lifts them up. However, for free you can't beat it.
Dick Davis
04-24-2001 04:44:05
How much is the operators manual for the 55?
Tim(nj)
04-23-2001 21:13:22
There's still quite a few in use around here. As long as you keep the gearbox lubed and keep the teeth from digging in the dirt when raking, they seem to last darn near forever.
Chuck Baesmann
07-08-2003 16:47:14
 Re: Re: #55 New Holland Hay Rake in reply to Tim(nj), 04-23-2001 21:13:22
I'm trying to get a manual on the #55 New Holland Hay Rake. Can anybody HELP me get a manual for this hay rake. I was told it could tedder hay? That is why I would like a manual for this piece of equipment. So I can use it to it's fullest capacity. THANK YOU, Chuck Baesmann cabaesmann@aol.com
