Grease fitting problems
Sam (MO)
04-24-2001 05:44:16
Morning
Is there a repair kit for grease fitting? Some of the one's are stripped out and when you try to give it a shot of grease the fitting just pops out.
Thanks for the information
Sam
Phil (VA)
04-24-2001 07:40:34
 Re: Grease fitting problems in reply to Sam (MO), 04-24-2001 05:44:16
You may have to drill out the hole, retap it, and put in a larger grease fitting. Lots of sizes available.
Charlie
04-24-2001 07:37:46
The repair is to put in a new one. You can buy them either one a time or in kits from hardware stores or farm supply stores/dealers. There are different sizes so it helps to take the old one with you when you buy one.
Sam Thanks
04-24-2001 12:54:07
 Re: Re: Grease fitting problems in reply to Charlie, 04-24-2001 07:37:46
Fella's
Thanks for the comments looks like time to get the drill and the tape and die set out.
thanks again
Dick Davis
04-25-2001 03:50:01
 Re: Re: Re: Grease fitting problems in reply to Sam Thanks, 04-24-2001 12:54:07
Not so fast with the drill and taps! Look at the offending ZERK carefully, some of these suckers are drive in instead of threaded. The drive in ones have parallel circular rings that look almost like threads and don't they don't have the hex shoulder for wrench tightening. There ia a confusing variety of styles and sizes out there. Good luck, my TSC always seems to be out of whichever Zerk I'm looking for. D-2
