Leveling Field after plowing
Mike
05-03-2001 03:43:08
Anyone know of a trick to level the field after plowing and disking? Have heavy corn stalks from last year, using a hare only brings it back up. Want to plant soy beans.
Thanks for any help.
paul
05-05-2001 12:26:09
 Re: Leveling Field after plowing in reply to Mike, 05-03-2001 03:43:08
Frankly, a slow soaking rain is your best bet. Much like we are getting outside the window right now....
Not that we have even thought about soybeans here. Still waiting for the ground to dry out enough to put in corn. I guess I finished with oats/alfalfa yesterday, planted a few acres, had to go around wet spots. Too late to try any more after the forcast 3 days of rain coming...
--->Paul
Dave
05-04-2001 05:05:09
I had to use a rotory plow behind a box scraper with the teeth lowered, and the blade held at about 3" up to break up the bricks I plowed up. Worked quite well. Ran at 45 degrees to the plow line. This was a sm. 1 acre pasture. Spike harrowed last.
Dave
Pine Grove
05-03-2001 11:49:42
Pan Plow and disk will do the trick.
Tim(nj)
05-03-2001 19:53:33
 Re: Re: Leveling Field after plowing in reply to Pine Grove, 05-03-2001 11:49:42
What's a pan plow?
paul
05-05-2001 12:22:14
 Re: Re: Re: Leveling Field after plowing in reply to Tim(nj), 05-03-2001 19:53:33
Gld you asked, I was wondering the same thing! :)
--->Paul
F14
05-03-2001 08:07:15
A disk (aka disk harrow) should do the job. The bigger and heavier, the better. Those little 5 or 6 foot 3-point hitch jobs are pretty much worthless in my experience. A hydraulic-lift wheel disk would be just the ticket.
Tim(nj)
05-03-2001 19:52:41
 Re: Re: Leveling Field after plowing in reply to F14, 05-03-2001 08:07:15
How about a roller harrow (aka cultimulcher, packer harrow)? You can engage the teeth for light penetration, which shouldn't pull too much trash up, and the rollers will leave a firm, smooth surface to put beans into.
