IH Sickle Mower
what to look for
Jim
05-03-2001 18:17:33
Will be checking out an IH Sickle Mower - draw bar mount for my H - what should I check out in particular - never owned a sickle mower before. Thanks, Jim
Charlie
05-04-2001 06:47:22
 Re: IH Sickle Mower - what to look for in reply to Jim, 05-03-2001 18:17:33
I've got one of the older IH mowers that bolts to the drawbar, has a single wheel in the back and the bar lifts with by hydraulic with a single action cylinder. If the one you're looking at is similar to mine, you can buy (or make) pitman sticks, guards and knives. What I would be most concerned about is the gear boxes. Mine has one the PTO is connected to and it runs the lower box by belt. The lower box runs the knives. If both gear boxes turn freely with no noises then they are in good shape. I think if one of these things had gear noises I would pass it up and look for a better one. The only other thing on mine the knife bar was bent, I think due to fatique and years of use. I was able to get a good one at a junk yard. IH made pretty good mowing machines - hope you get the one you want.
