Hyd. valve not centering
Micheal
05-12-2001 21:21:30
I have a control valve off of a loader. Don't know what kind it is for sure, think its a gressen 3-spool. The third spool is not centering. Can some one give me some ideas as to why. Is there a spring inside there to center it, or is it suppose to use hyd. pressure to center.
thanks for any help you guys can give me.
micheal
Steve (MD)
05-14-2001 17:03:39
 Re: Hyd. valve not centering in reply to Micheal, 05-12-2001 21:21:30
I just fixed a Gresen and found that there is a spring that is attached by a bolt in the back of the valve. The bolt head in mine broke off. I removed the valve and was able to twist the remainder of the bolt out with a pair of vice grips. Try not to nick the surface of the valve and lube it well before putting it back in. Best of luck...
Fudd
05-13-2001 20:52:55
Either the spring is broken or whatever holds the spring in place has come loose or broken. Good luck.
