How do I remove a slip clutch from gear box spline
Mark in VA
05-18-2001 09:07:33
I have an old Ford bush hog with a burned out oil seal. I need to remove the slip clutch from the shaft in order to remove the housing cover. I see no obvious nuts, bolts, or pins for removing it. Any ideas?
bill b va
05-18-2001 17:44:56
 Re: How do I remove a slip clutch from gear box spline in reply to Mark in VA, 05-18-2001 09:07:33
i have an old ford bushog . all i had to do was remove blade hub and using a center punch punched hole in old seal and pryed it out and drove in new seal.....bill b va
Dave
05-18-2001 10:24:02
My ford mower has a pin driven thru the splines on the gearbox side of the slip clutch. Drive it out. then wiggle and rock while tapping with a hammer.
