Grimm Tedder
John
05-23-2001 17:28:01
Does anyone have any information on Grimm Tedders? I have just recently acquired an old tedder. There is no tags on it. I believe it is a Grimm Tedder. I would like to find pictures or some sort of literature.
Rick Farnsworth
06-13-2006 19:00:51
 Re: Grimm Tedder in reply to John, 05-23-2001 17:28:01
I have a grimm tedder and just ordered parts for it from the factory. They are in Vermont and there phone # is 8027755411. I hope this helps. I was told they went our of business but that is not so. There parts man laughed when I told him that. I broke a gear and thought I couldn,t get one but a friend gave me there #. Good luck. Rick
SmallOps
05-24-2001 03:17:46
...Pleased to see you are seeking information on the Grimm Tedder and not the GRIM REAPER!
Sorry, I could not resist... :)
craig
05-23-2001 18:14:46
John, the grimms tedder is made in Rutlug, Vermont
by D.G.grimms corp. I have dealt with them before and they are great people. hope this helps you. Craig
Sam C
05-24-2001 11:44:08
 Re: Re: Grimm Tedder in reply to craig, 05-23-2001 18:14:46
Craig is right, although with a typo - Rutland, VT
The Grimm tedder I used to use was a reel type, with 4 bars parallel to the ground, with rows of teeth on each bar. It worked great in Timothy hay, but wasn't so good in hays that tended to clump, like clover and vetch. It is better on smoother ground, as it doesn't reach down into dips very well. We used to run it on a Farmall Super C, and used the 2-pt to raise and lower the height. My boss would tell me to drive it as fast as I dared (knowing that I'm not apt to beat on it too bad). Seems like we greased it well and often, and only had to replace teeth every now and then.
deb
05-06-2004 05:23:29
 Re: Re: Re: Grimm Tedder in reply to Sam C, 05-24-2001 11:44:08
Hey, just in case anyone out there is still acquiring Grimm Tedders...
I just did, and I'm getting ready to put it to work. By the way, the manufacturer is GH Grimm Company, 2 Pine St., Rutland, Vermont, 05701. Phone 802-775-5411.
