HELP ! Hesston PT-10 Haybine
JD
06-03-2001 15:42:14
Replaced the belt on a neighbor's PT-10. I put the idler pulley under the belt because that seemed to be the logical place. The belt has jumped out of the grooves and is rubbing against the wall.
Should I have put the idler on top, or is there some other secret to keeping the belt in the groove.
Unimog
06-03-2001 19:15:54
 Re: HELP ! Hesston PT-10 Haybine in reply to JD, 06-03-2001 15:42:14
JD, I have a PT-7 which I think is the same.
Starting at the rearmost pulley(V-side in grooves)
then up over the idler(flat side on pulley),down
under the lower roller pulley(V-side in grooves)
then over the upper roller sheave(flat side against sheave) to the uppermost pulley(V-side in the
grooves) over and back down to the rearmost pulley
I hope you can translate this but if you have any
questions, ask. Good luck, Unimog.
JD
06-04-2001 09:37:34
 Re: Re: HELP ! Hesston PT-10 Haybine in reply to Unimog, 06-03-2001 19:15:54
Thanks. That is how I have the belt installed on the PT-10 but it won't stay in the groves.
rhudson
06-06-2001 20:45:13
 Re: Re: Re: HELP ! Hesston PT-10 Haybine in reply to JD, 06-04-2001 09:37:34
JD, i just found my pt-10 manual, it added that the rear idler spring needs to be tightened until there is a "1 inch gap between the top of tension idler shaft and lower end of spring stop." it also notes that when installing a new belt to move the front idler to the rear most holes (there are three sets of holes). let me know if i can be of any help. cut about 15 ac. with my pt-10 today.
morgan1
07-29-2006 03:56:42
 Re: Re: Re: Re: HELP ! Hesston PT-10 Haybine in reply to rhudson, 06-06-2001 20:45:13
Is anyone able to send me a manual for Hesston PT-10 Haybine? I just purchased one and sure could use the manual.
Thanks
Alvin
06-03-2001 18:39:06
Check the owners manual, I don't remember, except they are d** costly to replace
