Bushhog seal leaks
VA
06-12-2001 17:19:24
Hi. My Bushhog brand rotary mower has a bad front seal. (Tall grass got wrapped around the shaft real tight and by the time I stopped it must have wore out the seal). I'm no mechanic and I mostly stick to external parts that bolt on and off, however due to the expense and or inconvenience of getting it somewhere to be fixed I might try to do it myself. I need to know if this is something for an amateur or not. It is an old bushhog model 12. I have no manuel or anything, what all is involved. Thanks, VA
John
06-13-2001 06:29:17
 Re: bushhog seal leaks in reply to VA, 06-12-2001 17:19:24
I just replaced the bottom seal on an old Bush Hog that was given to me. I think the front seal is the same. After removing a retaining ring I was able to pry the old seal out with a screw driver. Take the seal to your dealer and get the proper replacement. Clean up the seal area and gently tap the new seal in using the old seal and a block of wood. Replace the retaining ring. Not a difficult job. Good Luck
