Dumb Hay Raking Question
Bob Semrau
06-15-2001 06:50:00
I am used to raking with a Sitrex wheel rake, where I line up the left side of the tractor with the left edge of the windrow. On each new pass I start out with the left edge of the tractor lined up with where the previous pass stopped picking up hay.
I am going to try using an old JD 594 4 bar rake this time, where the tractor is hooked up to the right side of where the hay is picked up. What is the better way to line up - align the left edge of the rake with the left edge of the hay, which seems like kind of a pain because I will have to keep looking backwards, or to align the tractor with the windrow, but start on the second row in ?
The 594 does make better looking windrows ...
Thanks
paul
06-16-2001 08:44:57
 Re: Dumb Hay Raking Question in reply to Bob Semrau, 06-15-2001 06:50:00
Generally you only have to look backwards for a few minutes, then a person gets used to where you need to be.
--->Paul
Bob Semrau
06-16-2001 18:30:54
 Re: Re: Dumb Hay Raking Question in reply to paul, 06-16-2001 08:44:57
Yes - that's the way it worked out.
Thanks !
