Fordman has a pretty good soil prep below. Corn was originally planted 40 or 42 inches apart, so the horses would fit down the row when cultivating. Since the '40's rows have constantly been narrowed, slightly improving yield. Common row spacings are 38, 30 (most), 22 (matches beet equipment for those that plant sugar beets) and 20 (newest equipment, adds a bushel or so to yields over the 30" rows). So, if you were asking about top yields, I'd suggest narrower.... Since you just want a deer plot, buy the cheapest planter/ cultivator in good shape, and don't worry about row spacing, anything between 20 & 40 inches will be fine. If you ever plan to harvest the corn (most years you could still combine/pick it in spring if the deer left some) then I would strongly suggest co-ordinating your row spacing with whatever you will be using to harvest. One row pickers might fit through 24" corn, while most 2-row pickers are 38-40". Are you going to be replanting corn over & over in this field? If yes, insect pressures will get bad, and you'll need to add quite a bit of fertilizer. Will you rotate, maybe 1/2 corn, 1/2 oats & clover, alternate from one year to the next? Works well, no insecticides needed, helps control weeds better, and far less fert needed - but any leftover ear corn plowed down in spring will be quite a weedy mess in next year's crop, and this volinteer corn does not produce much of an ear, no feed value.... --->Paul
