Flail Mower, Finishing Mower, Rotary Cutter
Dave T
06-19-2001 04:49:12
I want to buy a mower to cut my lawn as well as occaisionally cut down tall weeds in a field. I don't understand the advantages/disadvantages of each type of mower. For example, clearly a Rotary cutter can handle cutting down tall weeds but can I use it also to cut my lawn and get a decent cut? I'm guessing a finishing mower would leave a better cut but can it handle weeds? I don't have a clue what a flail mower is best at. Any advice would be appreciated. Thanks ahead of time. Dave
Dirt Farmer
06-19-2001 15:36:52
 Re: Flail Mower, Finishing Mower, Rotary Cutter in reply to Dave T, 06-19-2001 04:49:12
I would invest in a finish mower. I have a 6ft. rear discharge Bush Hog. It cuts just as good as a lawn mower of the same width and will still cut some weeds and tall grass if you take your time at it. It will not cut weeds and brush like a rotary mower, but is not intended for that purpose.
rob 8N11071 KS
06-19-2001 08:21:17
It would help to know what kind of tractor you have.
A finishing mower will come the closest to a lawn mower.
You can get a decent cut with a rotary mower, but you can't cut very short.
Dave T
06-19-2001 11:45:11
 Re: Re: Flail Mower, Finishing Mower, Rotary Cutter in reply to rob 8N11071 KS, 06-19-2001 08:21:17
I would be using the mower with a Ford 860, so I'd want a 3pt pto arrangement.
Thanks
Robert in W. Mi.
06-19-2001 13:39:28
 Re: Re: Re: Flail Mower, Finishing Mower, Rotary Cutter in reply to Dave T, 06-19-2001 11:45:11
If i was buying it, AND you only want to cut weeds and grass, i'd buy a Woods REAR DISCHARGE finish mower. They do a nice job on grass, and will mow even heavy weeds just fine. Even small willows won't hurt it, but for my $$ it would be the rear discharge model. A rotary cutter (brush hog) just won't do a nice job on your lawn. Robert
