Mower-Conditioner Necessary?
agman
06-20-2001 07:26:38
Is a Mower-Conditioner necessary for 10 acres of alfalfa or is it just a big mechanical headache, and a simple Deere 350 Sickle mower all you need. Central Illinois where showers do occur and humidity can be high.
ed
03-24-2002 04:49:17
 Re: Mower-Conditioner Necessary? in reply to agman, 06-20-2001 07:26:38
ghzdtyse4
John
06-21-2001 22:50:12
Grass hay maybe. Legume hay yes. The leaves will dry before the stems unless the stems are cracked.
craig
06-20-2001 17:33:21
Hi, it just helps the hay dry faster by braking down the stocks. could be rough on leaves of the
alalfa good luck Craig
paul
06-20-2001 08:16:31
I only had a Ford 501 mower for years & years, did 6 acres of alfalfa & 10 acres of hay here in Minnesota. It works. No problem.
Last year I got a 1209 mo-co, and am doing 10-12 acres of alfalfa. It works better.
Still not sure if the extra expense & fuel will pay off on my acres, but there are more leaves on better alfalfa in the barn.
Either will make hay. If you have trimmimg & grass hay & so forth also, I'd suggest starting with the mower, add a mo-co if you find a good deal?
--->Paul
