Anyone good at math?
Kermit
06-21-2001 13:01:14
I've purchased a field roller. You fill it with water to add weight. The roller is 36 inches in diameter and 8 feet long. How many gallons will it hold? Also, how much does a gallon of water weigh? I've been told 8 pounds to the gallon, but am not sure if that's correct. I've been out of school too long! Somebody help, PLEASE!
Casey in Ky
06-22-2001 15:57:09
 Re: Anyone good at math? in reply to Kermit, 06-21-2001 13:01:14
Gee, thanks guys. You just give me a headache.....
Joe Evans
06-21-2001 20:31:24
Use Ford Man's volume figure and multiply that by 8.34 lbs/gal of water. Add the weight of your cylinder for total roller weight. Assuming 1/4" wall thickness of the cylinder and end plates, I come up with 913 lbs for the roller weight w/o water.
Ford Man
06-21-2001 14:14:11
Kermit,
1 cubic foot of water = 7.48 gallons
The volume of your tank is 56.556 cu ft . ( Pi x ( radius squared ) x height )
56.556 cu ft. = 423 gallons
1 gallon of water weighs 8.336 lbs @ 62 degrees
Therefore , the water in your tank would weigh right at 3,526 lbs.
Of course these calculations are only approximate because we do not know the wall thickness of your tank .
Thanks , I finally got to use some of the math from High School !
Ford Man
Tom
06-21-2001 14:11:23
The volume of your cylinder is pi x r squared x heigth or in your case 97,666 cubic inches. One gallon of water is approximately 6x6x7= 252 cubic inches, so your cylinder contains roughly 387 gal. If one gallon of water weighs about 8 pounds (you might check that 8 pound figure) then your cylinder will hold 3096 pounds.
hope that helps
Tom
Bus Driver
06-22-2001 17:25:00
 Re: Re: Anyone good at math? in reply to Tom, 06-21-2001 14:11:23
Apart from the math (well done), water in the roller will rust the interior until the oxygen in that fill is depleted- relatively little rusting. But winter demands draining the tank in freezing weather. Will rust when temp is above 50 and humidity above 50% even when empty. Many of the grading contractors fill their sheepfoot with diesel fuel to eliminate both problems. Diesel fuel is a bit lighter than water.
Tim(nj)
06-22-2001 18:48:06
 Re: Re: Re: Anyone good at math? in reply to Bus Driver, 06-22-2001 17:25:00
And a lot more expensive! I don't think the EPA would like it if you sprung a leak, either. How about filling it with water and some of the new non-toxic RV antifreeze? Also expensive, but not as much of a worry if you spill some. . . .
