Bush Hogging
briggs
06-22-2001 07:17:11
How bad is it for pasture to be bush hogged rather than hayed or grazed? I have about 30 ac of fescue and would like to keep it in decent condition,any suggestions?
Kermit
06-24-2001 13:46:38
 Re: Bush Hogging in reply to briggs, 06-22-2001 07:17:11
My pastures are bush hogged each year at least once. I usually wait till the fescure matures so that when I pasture clip it hopefully shatters out the seed which will drop on the ground and maybe help reseed the pasture. I also graze the pasture each year. I think it makes it easier for the cattle to deal with when you get the taller growth knocked down.
joe
06-23-2001 11:59:55
we mow ours every year. it is rented for cows. 20 come but it can handle 30. the pasture is well over 60 acres. mowing controls weeds before they seed and encourages second growth which the cows love.
Phil
06-22-2001 13:46:30
There is nothing wrong with mowing a pasture. You
only get out of a field what you put into it. If
you take hay off it or graze it you have to
replace what is removed. This is done with
fertilizer. Too often people graze their pastures
down to nothing and that is when the weeds start
to take over, they grow great in poor soil conditions.
The best thing to do (and it will save you money
in the long run) is to get a soil sample to find
out what the pH is and if you need any fertilizer. You can get a soil sample at you local Extension
Office or local farm supply store. Take samples
from alot of locations in the field to get a
representative reading.
A good stand of grass will choke out just about
all of the weeds and mowing helps. As you
continually mow the weeds the grass takes over,
providing the soil conditions are right. For
grass the pH is important.
briggs
06-23-2001 06:37:48
 Re: Re: Bush Hogging in reply to Phil, 06-22-2001 13:46:30
Thanks for your reply,the thing that bothers me with mowing is that the cuttings are left on the ground and create a patchy ground cover.Will that prevent the grass from reseeding? should I drag something like a harrow over it? Thanks.
Phil
06-22-2001 13:45:37
Tom A
06-22-2001 10:02:34
I'm still learning, but I'll give you my experience for what it is worth.
Bought a 19 acre farm several years ago; pastures had all been 'let go' and weeds, brush, brambles were rampant.
I've been bushhogging much of it for about 3 years, and have seen improvement, but there is still lots of weeds...not exactly prime pasture, but better than what is was when let go. I started haying off some of it last year, and those fields have improved slightly, but not too much difference that I can see. I let my neighbor pasture his cows on one field over the winter and early spring, and the difference is amazing! Virtually no weeds (well, lots fewer anyway) and the grass is growing back better and stronger than ever before.
So my bottom line is: not too much difference between haying and bushog; lots of difference between bushog and pasturing, as long as you don't exceed the land's carrying capacity.
good luck,
Tom
