Good or bad
scooterhead
06-28-2001 19:33:51
Looking at a 330 case baler , any good or bad opinions
B.C.
07-01-2001 07:55:16
 Re: good or bad in reply to scooterhead, 06-28-2001 19:33:51
I never heard much good or bad about them because there never was that many of them around.
If you can find a set of manuals for it, and at least one more machine for parts it might be worth it but I doubt it.
Short of that, like the other posts said, either JD or NH.
paul
06-29-2001 18:36:49
I too wouldn't want anything but a NH or JD baler. All the rest (in older models) do not have good knotters. You might just get one that works for you, but probably not.
--->Paul
Steven M
06-29-2001 18:25:35
I had a friend that had a Case 330 JUNK JUNK JUNK! C- ant A- fford S- omething E- lse
JD70Jim
06-29-2001 17:42:09
Another poster said that there are only TWO older balers. He is absolutely RIGHT and you should pay attention --- never buy a baler made by IHC, Ford, MF, AC, Oliver, or Case! I probably left out a few other loserbalers. Go find a real baler, and if it is not painted green and yellow, you had better be sure it says New Holland. Myself, I use the green one---a JD 337!
RickB.
06-29-2001 15:38:29
Where are you going to get parts? There are only 2 brands of older balers to consider, New Holland and Deere. Case Closed.
sammy the RED
06-29-2001 14:11:58
Just bad opinions from me about those junk balers.
