Adjustment on old Ferguson hay rake
Tom A
06-29-2001 04:29:34
I've got an old Ferguson 3 pt side-delivery hay rake. Is there a way to adjust the 'fluffiness' of windrows with it? I've got some pretty heavy grass hay that I'd like to fluff as much as possible to help it dry.
thanks!
Tom
Tom A -- thanks guys!
07-01-2001 03:34:36
 Re: Adjustment on old Ferguson hay rake in reply to Tom A, 06-29-2001 04:29:34
Thanks guys, I'll look for & try those kinds of adjustments.
Tom
Jerry D in NC
06-30-2001 16:14:38
Given the adjustments for rakes such as the Rolabars and JD's I would try to lengthen the toplink and see. Like Snuffy Said the angle of the basket changes the "fluffyness" of the windrow. The more vertical the front face the fluffier. That is why I would look for an adjustment on the rake that changed that or use the toplink.
Ol Snuffy
06-30-2001 07:02:28
Tom I am not familier with your rake but a lot of rakes have an adjustment that allows you to change the position of the teeth either forward or back, to accomadate different hay conditions. This adjustment usually pivits the whole reel up or down but is seperate from your hight adjustment. Take a look and hope this helps. Snuffy
