Ford dearborn 2 bottom plow
Keith_Md
07-03-2001 09:09:59
I would like to purchase a ford or dearborn 2/12 bottom plow. Does anyone know of one for sale, or a company that sells this type of used equipment. Are moldboards and shares readily availble still for this type of plow? Thanks for the help!
Jerry D in NC
07-04-2001 05:06:37
 Re: ford dearborn 2 bottom plow in reply to Keith_Md, 07-03-2001 09:09:59
Finding a 2-12 will be difficult as Tom said the 14's and 16's are alot more common. To get a double 12 keep your eyes open for a 3-12 because they werer sold as better plows for sod than 2-16's. Then you would have a spare point and moldboard.
Tom-Pa
07-03-2001 16:13:30
There is a farm supply near me in western pa that has about 10 of them in his lot. Both fergusons and dearborns. The hardest plows to get the parts for is the 12 in plows. the shares are expensive when found and the moldboards are usually the wrong one no matter what the catalog says. The 14 and 16 in plows the parts are readily available.
Good luck
Tom-Pa
Jerry
05-07-2003 19:07:03
 Re: Re: ford dearborn 2 bottom plow in reply to Tom-Pa, 07-03-2001 16:13:30
Saw your post on dearborn plows and am hoping you might be able to help me out. I was given A dearborn 2 bottom plow .The only problem is it has A broken molboard on the back.You said in your post that there is A dealer in western PA. I live in western N.Y. and if you would be so kind as to tell me where that dealer is I might find what I need
Thankk you!
Jerry
Hal
07-05-2001 16:24:43
This is a manufacturer of obsolete plow wear parts:
Crescent Forge & Shovel
405 W. Tinkham
Havana, IL 62644
309/543-3348
I have purchased some of their stuff, like 12" Oliver moldboards etc. thru dealers in PA. If you can't get the 12" Dearborn parts you can install Oliver frogs/bottoms on the Ford beams by just drilling another hole. Oliver made a moldboard #NC219-12 which I believe is still being using by farmers plowing with mules/horses.
In any event, if you buy a Dearborn/Ford or Ferguson, I would make sure it has the blade type "throw-away" shares, and not the long forged shares which will be hard to find and expensive.
Tom-Pa. . . almost forgot
07-03-2001 16:16:40
He also has a good supply of rolling landsides for the dearborn/ferguson plows. Email me if interested and i will send the info.
Tom
Keith_MD
07-04-2001 09:42:43
 Re: Re: Re: ford dearborn 2 bottom plow in reply to Tom-Pa. . . almost forgot, 07-03-2001 16:16:40
Thanks for the info guys. Tom I'll email you for the location of the plows in PA. I'm in Maryland so it shouldn't be to far of a drive to look at them. Thanks! Keith
