55ford with a wagner front loader
ken kinsch
07-05-2001 19:11:59
How do you go about changing the fan belt on this tractor.The shaft for the pump runs through the front frame work and I just cant figure it out?Any help is appericated. ken
Jim.UT
07-06-2001 09:45:31
 Re: 55ford with a wagner front loader in reply to ken kinsch , 07-05-2001 19:11:59
I couldn't figure anyway to do it either without removing the loader. The loader never got reinstalled after that.
plowboy
07-07-2001 19:41:00
 Re: Re: 55ford with a wagner front loader in reply to Jim.UT, 07-06-2001 09:45:31
Mark the position of the pump brackets and loosen pump to slide forward. Sometimes you have to break the little flex joint to pull shaft out far enough.
Some shafts are splined into drive plate on crank pulley and some are threaded in. Watch out for the little rubber sleeves in each pin hole where plate plugs into pulley.
