Freeman loader model number?
Michael Reahard
07-09-2001 16:09:49
I have a Freeman loader on an Oliver Supper 55 tractor. I need new seals for the hydraulic cylinders. The local Bush Hog dealer says he may be able to help me if I have the model number but the nameplate was lost years ago. The loader has a 40” trip bucket with manure forks. The hydraulic cylinders are single acting 26” stroke 1 ¾ “ rod. Is this enough information for someone to tell me what the model number is?
Leon E. Simpson
09-23-2006 09:28:17
 Re: Freeman loader model number? in reply to Michael Reahard, 07-09-2001 16:09:49
I have a Freeman loader on my WD and the cylinders are like what Paul describes. Mine is a model 40.
Ryan - IN
07-13-2001 09:29:48
Paul is right on with about the packing. Good luck getting the top of cylinder off though. I have broke 3 hyd. cyl wrenches trying to get mine off.
I ended up buying a 3pt boom for my AC D-17. I don't really use the loader that much anyway. It doesn't have a functioning bucket as of right now.
Paul
07-10-2001 17:41:44
Michael, I have an old Freeman loader that has cylinders with no piston in side them. They are made of pipe, and have a piece that screws on the end of the pipe that the rod moves through. The only seals in these cylinders are around the rod where it moves in and out of the pipe, and they are kinda like pump packing. Three bolts tighten the packing. The oil is pumped into the cylinder port and displaces the rod out the end. There's a keeper to keep the rod from falling out. If this is the type of cylinder you are working on, the packing is pretty cheap - a guy who works on hydraulic cylinders gave me an assortment of packing - said he didn't have much call for it any more. Hope you have as good of luck.
