AC 2-bottom plow
sid walters
07-11-2001 18:45:38
I am looking for a source for parts for what I think is a Allis Chalmers 2-bottom plow. I think the official term for the needed part is plow share, which is the replaceable point. The one I have is broken and has been welded several times. Part number is 14AC-A0121. Can anyone help?? Thanks
Chuck
07-12-2001 17:59:44
 Re: AC 2-bottom plow in reply to sid walters, 07-11-2001 18:45:38
First try locally at farm supply stores. Agco-Allis dealers should be able to help. You might also try online Wengers of Myerstown. Good luck.
Sid Walters
07-13-2001 03:10:13
 Re: Re: AC 2-bottom plow in reply to Chuck, 07-12-2001 17:59:44
Chuck,
Thanks for information, local Quality Farm & Fleet was unable to help. I will check out the other sources you supplied. Am I right in assuming it is an Allis Chalmers plow?
Bob Brown
07-14-2001 21:45:23
 Re: Re: Re: AC 2-bottom plow in reply to Sid Walters, 07-13-2001 03:10:13
I think to number you are looking for is a Dearborn, Ford or Fergusen number. I will check and see if we have it in stock. Check with us next week.
sid
07-21-2001 10:07:48
 Re: Re: Re: Re: AC 2-bottom plow in reply to Bob Brown, 07-14-2001 21:45:23
Bob, any luck with having one in stock??? I have still not been able to locate one. May try brazing my broken one.
