AIR DRILLS
AJZ
07-18-2001 10:07:46
I was wondering if it would be a smart choice to go with an air rig to do at least 600 acres of soybeans and wheaty per year. The seem to be simple and accurate. and you are nuch more efficient. I was thinking of about a 30 foot model with about 250 to 270 tow behind capacity.
Does anyone have any comments or reccomendations. I personally like John Deere but are there any other companies to look at?
Thanks,
AJZ
Green Envy
07-19-2001 17:51:34
 Re: AIR DRILLS in reply to AJZ, 07-18-2001 10:07:46
We have a John Deere 1820 49ft air drill. So far it is the best drill we have had on the place. The cart is easy to access and simpler than the Flexi Coil Cart. The tanks are plastic to you could visual see how much seed you have too.
John Deere Air seeding drills and seeders
1820 air drill - 29ft
737 air hoe drill - 31ft
735 and 1810 air seeder - 31ft
730 Air disk drill - 28 ft
1860 No till Air drill - 30ft
Actually, going against the other guy's posting, an Air seeder of the above sizes would be perfect for your 600 acres. It just that an air drill will cost more than a conventional drill and air drills are more complicated. They are however more convient such as loading and unloading the seed and you can wing the air drill up and go down the road.
Tim(nj)
07-18-2001 20:00:22
I don't see how you can afford this stuff on 600 acres . . . . nobody around here can.
