How to setup a set of plows.
Ron G.
07-20-2001 12:32:43
Does anyone know of a good source of info on the proper way to setup a set of 2 bottom plows. When there down, should they be level. How do I get they do go down to the proper depth? and stop? (on the first pass) How deep should I be plowing? I'm kinda new at this, so any help would be greatly appreciated
Thanks, RG
john
07-20-2001 16:45:16
 Re: How to setup a set of plows. in reply to Ron G., 07-20-2001 12:32:43
tell me what kind of tractor you are using so i can explain it better to you
Ron G.
07-21-2001 07:53:31
 Re: Re: How to setup a set of plows. in reply to john, 07-20-2001 16:45:16
An old Ford 9N, with a set of 12 or 14 in Massey Fergunson 2 bottom Plows.
Thanks for any info.
Tom-Pa
07-24-2001 04:21:16
 Re: Re: Re: How to setup a set of plows. in reply to Ron G., 07-21-2001 07:53:31
Ron,
The Ferguson Plow manual would be an excellent buy, it tells how to set up the plow and how to use it also..loaded with plowing information..Remember the 9N was designed to be a plow tractor and the manual was brought out to explain how to get the most use plowing out of it..(Ferguson sold the tractors,hence the Ferguson name on the manual...Ford made the tractors and sold them all to Ferguson and his sales system)Manuals are available several areas..check the books and manuals on this site at top of LH column or also available from N-newsletter.
Good Luck
Tom
Tom-Pa
07-24-2001 04:19:46
Ron,
Good Luck
Tom
