47 VAC implements
Jerry
02-27-1999 15:36:24
I have a 47 VAC with hydraulics. Not the standard 3 pt setup, but instead has 2 manually adjusted lower links and the upper link raises up and down hydraulically. What implements were available to fit this set up? Case only, or other brands? Any ideas on finding implements for this? I have seen several like it so they must be fairly common.
Dennis H.
02-27-1999 19:39:25
 Re: 47 VAC implements in reply to Jerry, 02-27-1999 15:36:24
Those would be listed as "Case Eagle Hitch". You can check the classified for possible sources, they will say "Eagle Hitch" in it somewhere...
Jerry
02-28-1999 13:26:29
 Re: Re: 47 VAC implements in reply to Dennis H., 02-27-1999 19:39:25
I believe the tractor I have pre-dates the Eagle Hitch system. It has no rockshaft and the top link is moved up and down by a hydraulic cylinder on the left middle of the tractor.
