Bush hog SQ60 vs SQ600
Paul Martin
08-01-2001 19:31:41
A local farmer is selling a 3 year old 5 ft SQ60 for $850 with slip clutch and is suggesting it is a medium duty mower. The only info at BushHog's website is for a SQ600 light duty model. What are the differences between the SQ60 and the SQ600?
Does anyone know what HP a Ford Industrial 3400 puts out (or PTO HP) or where I could go to find out? The Ford manual doesn't indicate this info.
thanks
Peter
09-10-2003 19:33:25
 Re: Bush hog SQ60 vs SQ600 in reply to Paul Martin, 08-01-2001 19:31:41
Just got an SQ60 with an 8N I got. Went to the local dealer and got a manual. On page 6 it states "The Squealer Cutters are light duty cutters designed for cutting grass and small brush."
I am clearing a pasture and it works fine for me eaven with an 8N.
Larrie Kitchen
08-09-2002 07:47:30
I purchased an SQ60 this year for 230.00 at an auction. It has a shear pin. I found it worked very good and have been clearing pasture / brush up to 2" diameter without much effort. I run it with a 36 HP tractor at 1800 rpm with no trouble.
JT
08-03-2001 07:04:19
I have a SQ600 which I think replaced the SW60. The SQ600 is definitely a light duty bush hog, not a medium duty. If I had to do it over again, I would pass on the SQ600 and probably get another brand all together. I have been very disappointed in this one. It vibrates like heck and I had to drill out the flange and put bigger shear bolts in it to use it (doesn't have a slip clutch). I put 11 bolts in it one day and broke half of them cutting johnson grass! The first one I got vibrated so bad you could hardly stay on the tractor. They brought me another one and it does better but still vibrates too much.
RickB.
08-02-2001 16:17:04
The SQ600 replaced the SQ60 this year. They are both good cutters when equipped with a slipclutch. Calling either a medium duty cutter is a bit of a stretch. I would call a Bush Hog 285 a medium duty cutter in 5' width.
hay
08-02-2001 08:14:56
i have a sq60 model bush hog. never heard of the sq600. maybe it is a newer model. my sq60 is a medium duty 5 ft. for the information on the ford 3400 go to this site:www.tractortips.com/
