Flail Mowers ??????????????
Russ
08-03-2001 10:16:37
Anyone have any thoughts about Flail Mowers?
I have a grass pasture and yard that I would be using it on. Have a 6 foot wide landscape mower (Woods, RM66) which work well on yard, but not to good in pasture. The grass is to high/thick. Would a flail mower work ok their? Exactely how does a flail mower work, anyway?
Thanks.....
scooterhead
08-04-2001 03:52:20
 Re: Flail Mowers ?????????????? in reply to Russ, 08-03-2001 10:16:37
Has anyone used a flail on brush , multiflore rose etc.
tom
08-04-2001 17:08:44
 Re: Re: Flail Mowers ?????????????? in reply to scooterhead, 08-04-2001 03:52:20
My flail (probably average retail flail) has spring steel knives. This machine can probably cut brush/saplings 1-2 inches.
One time when I was getting parts for my flail, the dealer showed me the knives that the DOT uses for their machines. They are cast iron hammers. The guy at the parts desk said that those flails can shred a wooden pallet (he saw it happen).
Flails can cut quite a bit. Depends on what you want.
TomH
08-04-2001 04:36:02
Anything up to about 2 inches is chopped up instantly.
Don Lang
08-04-2001 03:34:20
Russ: I strongly agree with John Healey.
I also own a 5' Mott mower and could not ask for a better cut in tall or short grass.
My wife used it to mow our 4 acre farm yard until she tried the new 720 bushog four wheel finishing mower and that is what we are using now.
So if you see anyone needing a 2 year old 5' mott mower with a set of new blades e-mail me at
langswelding701@aol.com Good luck.
Joe Evans
08-03-2001 19:21:49
I think that a safety issue is another advantage to a flail mower. Their discharge is directly rearward which precludes objects being discharged sideways into oncoming traffic along roadways while mowing. However, I do see a good number of rotary mowers being used anymore for road work.
John Healey
08-03-2001 17:21:31
Russ, I have a Mott brand flail mower and believe me it will mow a lawn or cut a field . My four foot wide mower has 120 l-shaped knives attached to a horizontal shaft. The knives pivot at the connection to the shaft which allows them to hit obsticles without bending. I have mowed hay and weeeds with mine 3 feet tall with no trouble. If you are interested I can scan some literature on the Mott that will show how it works, the different type blades, and just general info. If interested e-mail me. John
tom
08-03-2001 15:59:05
Flail mowers use a "verti-cut" system. A large drum spins parallel to the ground. Many hardened steel knives are attached to the drum. Due to the centrifugal force, the knives spin at right angles to the grass. The cut is excellent, probably the best of all mowers on rough. Other big advantage of flails is the guage roller. No need for those litte b.s. "anti-scalping" rollers.
In my humble opinion, only drawbacks to flails is that they are heavy, and a little more tedious to sharpen.
Around here (nw NJ) the state DOT uses only flails. Southern NJ is flat, there they use brush-hogs.
TomH
08-03-2001 15:57:45
To me, a flail mower is one that has a large number of small knives that are attached to a shaft which runs parallel to the ground. Imagine taking the blades off a reel mower and replacing them with hundreds of dangling L shaped pieces of metal that are attached loosly to the shaft so they flog whatever gets close to them.
The main advantage I see is that the little L shaped flails (usually about three inches by one inch) can beat on a stump, rock, or woodchuck mound without it being the kind major event it is when a rotary mower hits one.
Flail mowers don't work too well on long grass, it tends to bog them down. For pasture clipping I like a sickle mower, although a big rotary mower like a Bush Hog works okay too. If your Woods mower doesn't work its probably a lack of horsepower rather than the mower.
waffle
08-03-2001 21:58:26
 Re: Re: Flail Mowers ?????????????? in reply to TomH, 08-03-2001 15:57:45
I bought a older flail mower(1960's)that is pulled by a Allis Chalmer WD. I have used it one year and it works great when the grass is no higher than one foot. It is good for next to the road and any around the house to liten up the load on the garden tractor. As far as cutting the fields the flail mower bogs down to much so I use a brush hog. I do not know if the new ones work better in the fields, but this one works great for expanding the lawn. It leaves a real nice cut and this one only cost me $350. Good luck.
