Can I power a conveyor from the hydraulic power in my IH 3688?
ifitworksdontfixit
08-10-2001 21:27:38
I need to run a conveyor with a hydraulic motor that draws between 15 and 20 galllons per minute at 1200 psi. I want to use my IH 3688 tractor as the power source for the conveyor, preferably using the hydraulic sources by the PTO with the quick disconnects. I cannot find anywhere the specs re: flow and capacity of this system, so I do not know if I am wasting time trying this. Any info will be appreciated. Thanks
3 J's
08-24-2001 20:57:38
 Re: Can I power a conveyor from the hydraulic power in my IH 3688? in reply to ifitworksdontfixit, 08-10-2001 21:27:38
NO
Ross
08-11-2001 21:49:17
I have herd of guys who put augers on on gravity boxes to fill drills & planters & run them off of the hydraulic system & they work good. I have a friend who runs a backhoe of of his PTO that has a pump on it but he has a resivor on the backhoe trailer. Hope this helps
ifitworksdontfixit
08-12-2001 03:05:53
 Re: Re: Can I power a conveyor from the hydraulic power in my IH 3688? in reply to Ross, 08-11-2001 21:49:17
Did some testing today, I seem to be able to run it off two of the three hydraulic ports available. Each seems to have different flow rate though. Conveyor was empty. I wonder how it will do when full. Should know by Monday.
Cliff Neubauer
08-12-2001 06:51:40
 Re: Re: Re: Can I power a conveyor from the hydraulic power in my IH 3688? in reply to ifitworksdontfixit , 08-12-2001 03:05:53
Does the 3688 have the PFC hydraulic system? The PFC system has a 17 gmp pump and the old open center system was 12gpm. If it does have the PFC it will have a motor priority valve made for running orbit motors and maybe even a single hydraulic coupler on the left side of the rear end which is a direct return to the transmission to be used with orbit motors.
