HP needed for 7' disc mower?
Jason-Senoia, G
08-12-2001 20:50:39
What is the minimum PTO horsepower required to run a 7' disc mower? I hope to upgrade from my sickle mower soon. Also, does anybody have a recommendation on a good older small-size round baler (4' x 5' bales)?
Richg
08-16-2001 23:03:17
 Re: HP needed for 7' disc mower? in reply to Jason-Senoia, GA, 08-12-2001 20:50:39
I just bought a JF disc cutter and cut one of my fields for the first time today. It's a 7' cutter and I used a MF 165 (52 hp) with no problem the rating my cutter calls for is 42 hp.
john2510-3020
08-13-2001 11:53:44
we runa 7'10" jd 260 disk mopwer the minumem hp is 45 you can tget just a straight 7' mower it has to be eihter 6' or 7'10" no in between....we also use a 1999 model vermeer 504 super i round baler....i would look around for a 504 i roundbaler. it would be arond 10 years old. tehy just quite makeing hte super i's last year. the dif. between the i and super i is heavier bearings in the super i. also what kinda tractor you got? john2510-3020
Jason-Senoia, GA
08-13-2001 19:22:04
 Re: Re: HP needed for 7' disc mower? in reply to john2510-3020, 08-13-2001 11:53:44
I have a Case-IH 475 with 42 PTO HP. That is interesting about the incremental sizes of disc mowers - but it makes sense. I have seen some ads for 504 balers for sale. I will have to go and take a look at one. Is there anything specific I should look for on a used one?
