Hardee Bush Hog slip clutch
Eric Nulsen
08-13-2001 12:08:15
Hi, I smoked the slip clutch on a 7' Hardee Williams brand bush hog. I have replaced the clutch plates and the manual called for a 1 1/4" to 1 3/16" length on the tensioning springs on the slip clutch. When torqued to this length the clutch slips horribly.(barely enough friction to turn the blades without a load) Any ideas? The company is not answering phones.
Thanks,
Eric N.
grm
08-13-2001 16:13:31
 Re: Hardee Bush Hog slip clutch in reply to Eric Nulsen, 08-13-2001 12:08:15
Eric, just tighten each bolt a "flat" or two until it quits slipping and you should be ok.
