3 point quick hitch opinions wanted
Bob in Kansas
08-17-2001 07:48:44
I've been looking at the pictures of the 3 point quick hitch units in various catelogs. In theory they look like they would be time savers if hooking and unhooking 3 point equipment a lot. However, has anyone used one and if so, what are they like in real life - how do you deal with the various widths pin to pin from manufacturer to manufacturer?
Thanks in advance for the help,
Bob
jon Ks
08-21-2001 17:46:43
 Re: 3 point quick hitch opinions wanted in reply to Bob in Kansas, 08-17-2001 07:48:44
Hey, Bob, how 'bout tommy sells his that is leaning against the shed to Don who loves them so much. You seemed to get badly conflicting reports and two folks just told you to look at them some more, good advice huh? Good luck in your endeavor. P.S. if Don won't buy it, maybe you can borrow it to try it out.
Thank you all from Bob, KS
08-19-2001 09:25:02
Just wanted to say thanks to everyone for the information and the links. It brought out a couple of points I hadn't thought of, and helps in the decision process. Hope eveyone is having a great weekend.
Thanks again,
Bob
william l. brown
08-18-2001 06:28:13
BOB, try this website.
www.tractorbynet.com
click on kubota owning,
click on hooking up implements.
there is one called the
freedom hitch that looks good to me.
william
tommyw
08-17-2001 17:29:37
i have a cat 3 quick hitch for my 5088 the problem is i have cat 2 and 3 implements.a cat 3 wont fit 2 and so on,my quick hitch is leaning aginst a shed right now. if you have one type of implements it would be okay i guess, ill never waste my money on another one its too much hassle it actually cost me time.a neighbor has a cat4 on a 7140 magnum we had to take it off also it wouldent hook to his 17 shank ih cheisel.
ShepFL
08-17-2001 12:47:28
Bob -
I have been looking at these for some time now. I just discovered Delta hitch last week and also provided a link. Another site is Jiffy Hitch Systems located here in Jax, FL. Link below.
Since I am the only one hooking and unhooking as you know it is sometimes a real pain in the arse. I really like the idea and am strongly considering building something.
Costs that I have seen so far is between $300-600 per attachment which is to spendy for me now. Hydraulic toplink is very spendy IMHO but would think beneficial. I would consider only puting on most used equipment i.e. bush hog, disk, and possibly the plow.
I have spoke with owners of the Jiffy Hitch and they swear by it, I seen it action at a fair last fall and sure seemed slick. However, at this I have more pressing equipment needs (seeking 8-12 disk harrow). Best of luck with your efforts, maybe next yr the budget will permit one.
Don
08-17-2001 12:08:39
I have used them for the last 12-14 years and the y are a Godsend as far as I'm concerned. I have a category 2 and a couple of category 1's that I bought at TSC. Over the years I have had to modify an implement or two (put longer pins on, etc, nothing major.) but I would trade the implement before I would get rid of the quick hitch. Once everything is set up they are a real time saver.
Tom-Pa
08-17-2001 11:58:27
You might want to look at the Delta hook...it is another option for options hitch attachments.
