Fergusion-Sherman Plow
blair
08-23-2001 10:18:32
I would like to know a little more information on the plow I own. The nameplate has on it -Fergusion-Sherman, Model 10H. What time frame would this plow have been used in? Would it be used with 9N,2N or 8n tractors or the Fergusion tractors, TO,TE? I know the 10 refers to width of the furrow but where is that measured on the plow and lastly what does the "H" refer to. Thanks for any history or info.
Blair
Brad McMillan
10-24-2003 11:37:44
 Re: Fergusion-Sherman Plow in reply to blair, 08-23-2001 10:18:32
Hello.
I also have a Model 10H plow that no one has ever heard of. Unfortunatley, mine was (is) all out of adjustment; I think someone was trying to make it plow wider. I hope you'll contact me so we can discuss. My number is 705-653-3425, or you can e-mail.
Brad
Tom-Pa
08-23-2001 11:08:42
He did have a model 10HB-AO-28 plow with 10" scotch points on it. It was used with the 9N in the beginning. He had the Sherman brothers in it then..Later had a falling out with them..They also made the plow for the Fordson that helped prevent flipovers..had a second higher attach point on back of the tractor and plow. The are measured from the inside of one main beam to the outside of the next main beam.
Good Luck
Tom-Pa
