Ford 530 baler needles
jeff flaharty
08-24-2001 22:16:16
Does anyone know where I can find a pair of needles for this baler?
Busted off in brogue pa,
Jeff
Dan
08-31-2001 10:35:41
 Re: ford 530 baler needles in reply to jeff flaharty, 08-24-2001 22:16:16
We broke one of the needles in the middle, had it brazed together. Was afraid to weaken it too much by grinding the material down flush, so ended up with the braze material being about 3/8" high all around the break. Baler worked fine for years after that.
Tom A
08-25-2001 14:25:38
Might try your New Holland dealer, they seem to stock every other kind of old Ford parts.
Also, had the same problem with my old MF baler (2 broke needles). MF dealer wanted $135 apiece for the needles...found a good local welder (not run of the mill, but a fabricator kinda guy) who repaired both of them for $100. Year later, they're still holding together.
good luck,
Tom
paul
08-26-2001 11:34:03
 Re: Re: ford 530 baler needles in reply to Tom A, 08-25-2001 14:25:38
Local welder had jigs set up o weld needles, our work as good as before we forgot to time the baler. (Blush.)
They are kinda rare, but you can buy a whole baler for $50 or so around here of that model...
Couple options.
--->Paul
