Grain drill and plow
Gary Dunn
08-25-2001 14:14:05
Have an old John Deere grain drill , Van Burnt, with 38" X 6.50 tires,rubber. Wondering what yr this was made?
It is 16 disc and approx. 10 ft. long with all the disc and double hoppers for seed or fert. Is there a serial no. located somewhere?
Also 5 disc John Deere bottom plow with large weight wheel at rear. Number somewhere? Any info on either or approx yr and value appreciated. Thanks, gary
Bob Collins
08-26-2001 11:30:17
 Re: Grain drill and plow in reply to Gary Dunn, 08-25-2001 14:14:05
Gary, I'm guessing here because it is hard to visualize sometimes with minimal info, but I think you may have a disc tiller rather than a disc plow. A disc plow has each of the discs mounted on its own individual standard, like a moldboard plow, a disc tiller sometimes called a "one-way disc" or just a "one-way" has the discs mounted on a common shaft like a disc harrow. The reason for the massive weight on the rear wheel is to help fight the side draft since there are no landsides as a moldboard plow has. If I am guessing right, I think you may have a number 250 disc tiller, from the 1930s and 40s. If it is actually a 5 disc, disc plow , I hope someone who knows more will respond, I'd like to know more too. Bob
