Ferguson Hay-bailer #12
Astrid Hall
08-26-2001 15:05:22
I need needles for my Ferguson hay bailer, serialnr 687004MI, Canada 6Bf. Help
ksmith
08-26-2001 16:49:35
 Re: Ferguson Hay-bailer #12 in reply to Astrid Hall, 08-26-2001 15:05:22
I have a #9 (I use) and a 12 (Parts). The 9 and 12 parts are interchangable ... the 10 is older so I don't know if the parts are interchangable. The only difference is that the 12 has a fancy driveshaft/clutch. What is wrong with the needles... my eyes were worn and my baler guy built them up with braze (He usually uses stainless but the needles had been built up once with bronze so it had to be bronze again ... he says it will last 10,000 bales before rebuilding again.
Tom A
08-26-2001 16:24:55
I have two MF 10 balers, suspect the needles are the same as the 12, but am not sure.
You might try finding a *good* welder locally to see if he can fix your old ones--I did that on one of the balers and they have never failed. I do have a couple of spares, though.
If you think they fit, you're interested, and can't find anybody to weld yours and can't find them anywhere closer to you (I"m in Maryland, USA), drop me an email and we'll see what we can do.
Good luck,
Tom
