Sounds like folks are describing different kinds of soil here. With hills, do you happen to have a lot of clay in your soils, and did it happen to be quite dry (or very wet too) when you plowed? For the future, it helps to plow the ground, and then about 4-8 hours later run over it with a harrow (spike-tooth drag). If you wait any longer the ground will bake into bricks, sooner & it will mash down into hard ground again. You want to hit it when the outside of the lumps are getting hard & cracking, but the middles are still damp. It will fall apart pretty well at just that right time. You could use the disk if you don't have a harrow, but you are better off with a wider harrow & just knock the lumps around a bit, less tractor tracks in the field. Timing with the rains can also do this now. You will not get a good seedbed if it's dry now anyhow, so just sit back & wait. When it rains, try to hit that 'sweet spot' when the field is drying out a bit, but the lumps aren't dried out rock-hard again. Roll over them with the disk, don't angle it much, and it should cut them up a bit. Caution, in damp/wet conditions a disk will QUICKLY roll the ground into a hard-packed concrete again, so only go over it once, give it time to dry. Here in Minnesota we plow in fall, let winter freezing & moisture mellow out the soil & have an easy to prepare seedbed in spring. That would be ideal, but we can't always do what is ideal, huh? :) You can run over the field with the backblade turned around backwards, drive forwards. But, it isn't ideal, and it does cause a few grins from the folks driving by.... ;) ;) --->Paul
