Dearborn Disk ( EZ Lift)
Fred
08-28-2001 11:40:22
I'm trying to rebuild this old "great piece of History" and the wooden boxens are worn out. I've replaced all of the bolts in the frame and have the blades on hand to replace the broken ones with. Now, I'm planning on making the wooden boxens out of a block of oak or hedgeapple. Has anybody else tried this? I would appreciate any suggestions. I'm told the boxens are available somewhere but are about $20.00 each and I need 8 of them. Can someone help with info? Thanks, Fred.
ca
08-28-2001 12:09:39
 Re: Dearborn Disk ( EZ Lift) in reply to Fred, 08-28-2001 11:40:22
If these boxbearing are the ones for the spindles. A few year back at the farm show in London Ontario at a display for potato digging equipment the rep showed me the wooden bearing in the tube chain rollers.I believe they were made out of maple wood them boiled in bee's wax. He said as they turn the wood warmed up and the bee wax lubricated them.He said they were the only bearing to stand up to the dirt and abrasion on there potato diggers. I don't know if this would work on a disk, It's just a thought. Good luck
Leroy
08-28-2001 14:00:50
 Re: Re: Dearborn Disk ( EZ Lift) in reply to ca, 08-28-2001 12:09:39
Use hard maple, what orignals were made of, soak in oil for quite a while before installing, best for absorbing and holding the grease.
Jhill
08-29-2001 07:27:22
 Re: Re: Re: Dearborn Disk ( EZ Lift) in reply to Leroy, 08-28-2001 14:00:50
I agree with the maple hard maple and soak in oil.
Fred
08-29-2001 07:48:24
 Re: Re: Re: Re: Dearborn Disk ( EZ Lift) in reply to Jhill, 08-29-2001 07:27:22
Great!!! Thanks, I'll start looking for the hard maple.
