EZ-Flow seeder
Brian
08-30-2001 14:34:58
Is an older drop spreader worth putting new rubber on? I was thinking of using it to seed and fertilize a new lawn, hay, oats, etc. Would I be better off using an endgate seeder?
larry
03-10-2002 10:01:21
 Re: EZ-Flow seeder in reply to Brian, 08-30-2001 14:34:58
farmers in my neighbor hood liked it better than a john deere.
Garidgerunner
09-03-2001 03:01:04
You might do like I do. Go to the local tire dealer and have some good used tires put on. have had good used tires put on for $10-$15 each. a good option if not runing on the road much.
Brian
08-31-2001 21:13:30
Thanks guys, I was wondering if I brought home a piece of junk from a recent auction. I bid a buck and nobody raised the bid! It had been shedded it's whole life.
Dave in Mo
08-31-2001 09:29:12
I use my E-Z flow drop spreader every year for lime applications. Works great still, there's very little to go wrong with it.
Tim(nj)
08-30-2001 19:56:33
If it's not rusted out, sure it's worth putting rubber on it. If you try to plant oats with it, you should drag an old spike harrow along behind to mix in the seed.
charlie
08-31-2001 17:04:26
 Re: Re: EZ-Flow seeder in reply to Tim(nj), 08-30-2001 19:56:33
i only use mine for lime nowadays,but in her day she was a jewel.one of the tires on mine is a fat freddy white wall.i've still got the owners manual if you need to know a setting.good luck
