Hope someone can help identifying a cultivator.
lpc
08-31-2001 21:36:58
May receive it in a trade deal. It has a chain drive from each spoked wheel(two) that runs a shaft to some sort of mechanism that looks to at least adjust height. This mechanism is mainly drum styled with a large dog or catch area on one side and also a handle that allows engagement or pass operation on these dogs. There are also hand cranks for these adjustments. There are 8 gangs of 3 "teeth" that have arrow shaped points on them. It's pretty close to 10 feet wide and the spoked wheels hold rubber tires. I really don't know if it's even a cultivator. Looks like a spring tooth harrow only up off the ground and the teeth aren't just spring width. Help?
Dave C
09-05-2001 10:21:02
 Re: Hope someone can help identifying a cultivator. in reply to lpc, 08-31-2001 21:36:58
Sounds like it is a John Deere field cultivator used for general tillage as opposed to row crop cultivating. The drum devices with the dogs are lifting mechanisms operated by pulling a rope from the tractor seat like on a rope trip plow. Some of these machines had 2 lifts, one for each half of the machine. Some just had one that would lift all the digger arms. The arrow shaped diggers are "sweeps" for cutting a wider path and digging up the weeds. You could use various types of sweeps for different applications. Narrow, straight points were often used to till fields with quack grass growing in them. The points brought the quack roots to the surface for the sun to kill them.These machines were sometimes called "quack diggers" also.
JIM
09-01-2001 16:49:02
IT SOUNDS LIKE YOU MAY HAVE A JOHN DEERE MODEL CC CULVATER I CAN'T BE SURE WITH OUT SEEING IT GOOD LUCK . JIM
paul
09-01-2001 10:09:09
1. What location are you in? Different regions have different machines, location _always_ helps with the questions I see of late! :)
2. Is this a row crop cultivator, or a field cultivator? Sounded like a row crop, but 8 gangs does _not_ work out, row crops have an odd number of gangs most of the time.
3. To me 'arrow shaped point' sounds like cultivator sweeps, are these small (couple inches to 4 inches across) or large (8 inches to a foot across)? The large ones are sometimes special built field cultivators made to kill quck grass or Canadian thistle patches 'here'.
4. But then you mention 'spring tooth harrow' which 'here' is a whole different thing, just has springs on it like side rake teeth, no cultivator sweeps. So this throws me a little?
5. Are the sweeps (or spring teeth?) mounted on a ridgid shank, a ridgid shank with rock-trip springs on it, a 'J' shaped springy flat iron, or an 'S' shaped springy flat iron? The first 2 are ridgid mountings, the last two are versions of spring or 'Vibra-shank (TM)' type mountings.
6. As always, a picture is worth a 1000 words... ;)
--->Paul
lpc`
09-01-2001 22:10:22
 Re: Re: Hope someone can help identifying a cultivator. in reply to paul, 09-01-2001 10:09:09
Ha! Sounds like you're the man I'm looking for. lol
#1 Ok, I'm in western Oregon.
#2 I don't know about the row crop/field because I don't enough about cultivators yet. At this point I'm partly guessing it is a cultivator. It has 8 arms that hang back and pivot from the main frame, with 3 spring type hooks and teeth mounted on them, each hook and tooth about a foot and a half behind and offset form the forward one.
#3 The teeth look like giant arrow broadheads, about 7-8 inches across. There are coil springs that must be there to apply down pressure on the teeth. The last gang on the left is designed to be missing the front tooth.
#4 I could be totally off on the spring tooth harrow thing, I admit I know nothing about the implements yet. That's why I'm here asking questions and listening to you folks. There's a harrow (by picture discription) in the implement photo section that has the "hooks" I'm comparing to this "cultivator".
#5 The teeth are mounted on a arm that comes back from the pivot on the frame, from these arms are the flat bar springy looking "hooks" (that look like the hooks on the harrow pic), 3 to an arm, staggered front to back and offset to the right at each position to the rear. There are adjustable springs that looks to apply down pressure on these arms. The teeth obviously mount on the bottom of these spring bar hooks.
#6 I would truly love to be able to provide a digital pic but I and my freinds are still too far in the 19th century. If it comes to that I'll try to find a loaner from someone. #7 Thanks you for your patience, knowledge and help, Loren.
