Ford 211 5'brush hog clutch
Phil
09-02-2001 17:34:05
I have an old, 211 5' Ford rotary mower and the clutch slips quite regularly. The friction discs are about 1/8 inch and and the other 1/16 inch thick. I suspect they come much thicker new. The local tractor repair place (now out of business) told me there was no way to replace the friction discs, but the part came apart as though it was intended to be repaired. Anyone ever replaced the friction discsin one of these? How thick are new ones, and is this a reasonably available part? I dont think the discs I have now would ever work properly unless I used shorter pass-through blocks than the originals that space the bolts holding the clutch together.
Thank you.
Phil
