How old is this Dearborn plow?
Haycreeker
09-07-2001 19:47:51
I recently aquired a Dearborn 2 bottom, 3 pt hitch plow. Curious as to how old it might be, Its in nice shape, colters and cam type adjustment. Model # 10-1, Serial #48196. Thanks
Plow Boy
09-13-2001 16:44:41
 Re: How old is this Dearborn plow? in reply to Haycreeker, 09-07-2001 19:47:51
Haycreeker if you need additional Dearbourne plow information including setup please go here>Link
I>Link just might help and it's FREE
Bill (SC)
09-10-2001 05:53:57
N-news.com sells the operating instructions for this plow. Look under master archives.
Sam MI
09-08-2001 06:16:57
Hey Haycreeker: I also have same plow serial number 85810. It's my understanding that these 10-1 plows were built from 1947 thru 1950. What is the diameter of the coulter disc's on yours? Mine are 13-1/2" but the book shows 15-1/2". HTH
Farmer Tim*8N15513*
09-21-2001 17:25:28
 Re: Re: How old is this Dearborn plow? in reply to Sam MI, 09-08-2001 06:16:57
I have a Dearborn Economy Plow 2-bottom 12" model 10-152 which has 13-1/2" coulter discs. The discs only came in two sizes: 15-1/2" and 18" in plain ( round ) or notched ( wavy edge ). The A/O manual says to keep the ground engaging parts sharp, so I'm sure they were sharpened a lot. I recently vaporblasted mine down and I could see that the edge was sharpened. Also, I'm sure they did a lot of work in their days. They were optional equipment, but if you bought a plow, you bought the coulters and jointers too.
Haycreeker
09-09-2001 20:20:40
Leroy, My front coulter is 13 1/2 inchs, rear one 15 1/2 inches! Got me wondering if that is original equipment, everything else is all in place, never been monkeyed with. Have you ever adjusted it using the cam adjuster? I'm having a hard time getting it plowing level with my Case tractor. Thanks again.
Leroy
09-09-2001 07:17:05
Anything that carried the Dearborn Name would have been made between 1948 after the split with Ferguson and 1954 with the last of the NAA tractors, with the start of the No. series, 600, 700, 800, 900 Ford droped the Dearborn name and just used Ford.
