3 PT sickle bar mowers
SamMI
09-08-2001 06:25:53
Searching for mower that will operate at inclined angle. I.E. ditch mowing. I guess the FORD 515 mower would do this chore but are there other mowers that will also cover this work. All info appreciated.
Kermit
09-14-2001 01:44:59
 Re: 3 PT sickle bar mowers in reply to SamMI, 09-08-2001 06:25:53
I highly recommend the New Holland 451 mower. I've owned one for years and am very satisfied with it. I use it to mow hay with every year. It will work on inclines as it is a wobble drive. It is easy to mount, simple to maintain, and cuts great. Excellent machine.
Dustin
09-10-2001 21:09:00
I use a Ih #100 balance mower, 3pt,it could have been ordered with the fast hitch or pull type, it is pitman-less, and if you adjust the gag-rod loose enough, the bar can go lower than tractor as far as needed.
SamMI
09-10-2001 05:10:38
Thanks guys for the info. Guess I'll be looking for a pitman-less mower.
Jerry
09-09-2001 09:52:10
I use a New Holland 451, 7' bar, which is pretty well made. I use it to mow road ditches and seems to angle down well. I think the owners manual suggests nothing lower than 15 degrees, but it probably droops down a good 20-25 degrees at least with no problem.
As one person mentioned, it is a little tricky to hook up.
Roddie C
09-08-2001 23:59:03
I have a John Deere 350 and a IH 1300 both have belt drive and will cut at any angle. I have used a New holland that had a belt drive I believe it was a 451 it did a good job also but was harder to hook up to the tractor. I hope this helps all three are good mowers.
Jim.UT
09-08-2001 21:25:29
I don't have personal experience with it, but I believe International Harvester made a belt drive, pitman-less sickle mower that would work at an angle.
Ira
09-08-2001 18:45:46
I am using at present a M/F 32 3pt sicle to the sides of our septic mound.does a pretty fair job.i don't believe any of the older were made to
work at an angle.
