Balers with a Thrower / Kicker
Dave
09-15-2001 18:37:40
I just bought a 8540 C-IH baler with a thrower on it and before I remove the Thrower I would like to know if anyone has used a Thrower to put bales on the Rack with someone{ME} stacking them? Don't want to remove the Thrower, but I don't want to start Buying Racks with sides yet either. This is probibly a DUMB/UNSAFE idea but I thought I would ask. Thank You!! Dave
Harold Hubbard
09-17-2001 03:56:39
 Re: Balers with a Thrower / Kicker in reply to Dave , 09-15-2001 18:37:40
After a bale took the hired man right off the top of a 12 ft. high load, I haven't been able to find anybody dumb enough to get back onto the wagon!
TomH
09-16-2001 12:07:48
We do that all the time. Most throwers can be adjusted to just toss the bale gently onto the front of the wagon. Building sides on the wagon is a good idea anyway.
Tim(nj)
09-15-2001 19:39:56
Why not just add sides to the wagon you have? I did it with two old flat wagons that had been my grandfather's when I switched from JD 336 w/chute to 336 w/ejector. Balers are usually balanced special for the thrower and removing it could be more of a pain than you think.
Another thought- suppose you disconnect the pump drive and loosen the pressure between the thrower belts and just let the bales slide out and hook them, like off a chute?
Duner Wi
09-15-2001 18:49:25
You are going to be so busy dodging bullets you won't have time to stack any hay. I think you will have more excitement than you can stand.
