54a kicker
mm
09-19-2001 06:05:27
I have a roller bearing that went out last week. I am having a tough time getting the collar off (set screw) is not coperating I tried using all types out petroleum products and nothing seems to lossen it up and ideas?
Mark A
09-19-2001 07:03:51
 Re: 54a kicker in reply to mm, 09-19-2001 06:05:27
If the bearing is ruined already, sometimes you can just weld a bead around the center of the stuck part, and as its hot, it will come off because of thermal expansions and or contractions. Good luck
Jeff
09-22-2001 14:16:42
 Re: Re: 54a kicker in reply to Mark A, 09-19-2001 07:03:51
Heat is the best answer provided none of the surrounding surface are heat treated. I doubt this is the case. Just get it hot with a torch and if it does not want to move, let it cool and try the same process again. I have had good success with this method. Though an oxy acetylene torch and rosebud is most desirable, a small propoane torch may work also. It just takes patience. Worst case scenario, use a cold chisel to cut the collar. Good luck.
