You might be able to find an old loader that doesn't have a decent bucket for pretty low $$. That would give you something to start from, and it also has the advantage of being able to lift the blade completely above the snow so you can back out when you get stuck! Build it tougher than you think it needs to be, put some weight on the back of the H, and it will surprise you! When the '78 blizzard came through here (I live about 14 miles N of Indy) the SM was equipped with the loader and blade, but in a barn with only one door large enough to exit. There was a drift on the East side of that barn (where the door was) that went to the top of the 14' overhead door, and stretched out about 100 yards into a field. After spending half a day getting the door open, I started the tractor, and let it warm up for about a half hour. It had a heat-houser on it, so it was warm clear through. I put it in 4 gear, and had about a 30' running start with the blade about 3" off the floor. When I hit that bank, there was an eerie silence as the tractor and I were buried in the snow. The tractor was still running, so I dug myself out enough to climb off and get back into the barn to look at the situation. It wasn't pretty. I spent about 2 hours digging that tractor loose enough to back it into the barn and try again. On the third or fourth try, I actually broke out to where I could turn around. When the county finally opened the road, a neighbor with a JD 3020 and a rear blade teamed up with me to open some driveways. You won't have the momentum with an H that I have with the SM, but you will have a pretty good snow mover!
