Driveline for c-21 mower
Scott
09-24-2001 11:43:33
I've got the Super C all rebuilt and ready to go and have turned to the mower. Can't start planning too soon for next year. Now I'm faced with a problem I thought I saw before I started tearing things down. When I bought the tractor with the mower mounted, the front half of the driveline was missing. It looks like someone once tried to weld the mower end of the driveline directly to the u-joint on the front/splined end. When the mower is raised, I measure 9-1/2 in. between centers of teh u-joints -- at bottom that lengthens out to about 10-1/8. I'm not real sure how mcuh working length will be left if I take into account the slack needed to get it hooked up after the mower is mounted. My two questions (finally) are a) can anyone suggest sources for shafts that short and b)I'll entertain all suggestions as to how to get the threaded end of the shaft off of the mower. (I have already the left the working end of my lineup punch in the hole in the shaft.)
TIA
