52 A (john deere) baler
doug vose
09-24-2001 13:45:49
I have come across a 52-A baler, it hasn't been run for a while and i am pretty sure it is almost all there. but i was wondering if anybody has any pictures they could post. multi angles would be great! thanks in advance.
also what would be a good price to pay for it. it is missin the right wheel, and the chute, that is for sure. it is rusty, but you can still se the painted john deere on the side.
Leroy
09-24-2001 18:31:26
 Re: 52 A (john deere) baler in reply to doug vose, 09-24-2001 13:45:49
How did you come up with that model number? 116 was built from 1946 to 1956, 114 from 1951 to 1956, 14T from 1955 and then 24T and 24W and then the newer models, 52-A would not be a baler model.
doug vose
09-25-2001 12:30:37
 Re: Re: 52 A (john deere) baler in reply to Leroy, 09-24-2001 18:31:26
it was on the serial no. plate
Leroy
09-25-2001 17:12:24
 Re: Re: Re: 52 A (john deere) baler in reply to doug vose, 09-25-2001 12:30:37
Describe the baler then we may be able to figure out what you have, Leroy
doug vose
09-25-2001 18:05:33
 Re: Re: Re: Re: 52 A (john deere) baler in reply to Leroy, 09-25-2001 17:12:24
it is one of the right angle dealies. the hay/straw comes straight from the pickup and into the compression chamber without any cross-conveyor. the bales are then laid on the ground. comp. chamber ----- l l
pickup
Leroy
09-26-2001 05:29:30
 Re: Re: Re: Re: Re: 52 A (john deere) baler in reply to doug vose, 09-25-2001 18:05:33
Is it a wire tie with two rolls of wire on top and two rolls on the bottom of the bale chamber? If it is measure the bale chamber and see if it measures either 14" or 16" in height. Sounds like either a 114 or 116 baler.
doug vose
09-26-2001 12:04:18
 Re: Re: Re: Re: Re: Re: 52 A (john deere) baler in reply to Leroy, 09-26-2001 05:29:30
i will check the hiegth ASAP. if it is 14", is it a 114, and 16" a 116 or visa versa
Leroy
09-26-2001 14:19:24
 Re: Re: Re: Re: Re: Re: Re: 52 A (john deere) baler in reply to doug vose, 09-26-2001 12:04:18
Correct, 14 a 114 more scarce than 116,I have 2 -116 balers, early version and late version. Leroy
Leroy
09-30-2001 17:03:47
 Re: Re: Re: Re: Re: Re: Re: Re: 52 A (john deere) baler in reply to Leroy, 09-26-2001 14:19:24
Did you ever figure it out?
